An attempt to send a conduit event message to an IO blade failed. The underlying system socket has failed and is closed as part of the recovery.
This may be a result of low system resources, and may be resolved by reducing the number of features that are configured on the switch. Otherwise, report the problem to your switch support contact.
Error
A conduit event transmission failed for slot %slotNum%, conduit type %cndtType%, socket %fd%, errno %err%(%errStr%) .
| Name | Type |
| slotNum | uInt |
| cndtType | String |
| fd | uInt |
| err | uInt |
| errStr | String |
